Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tunnel ram bogs
Thread: Tunnel ram bogs
  #69 (permalink)
Old 05-01-2013, 05:53 PM
Fang16's Avatar
Fang16 Fang16 is offline
Last journal entry: Project change
Originally Posted by F-BIRD'88 View Post
what is the file name and addy of the most recent file you want me to look at.?
The one with the 600 carbs on the motor.
what is the defect on the 750 carb? If it is a real manufacturers defect like a casting flaw/Edelbrock may replace it for you.
But you have to ask.
Open up the AFR text file and edit it by writting in showing aprox throttle position/engine load/driving mode/rpm
In each area so I know what the engine is doing.
resave and
post the AFR file txt here.
That is the easy way for me to evaluate it.
The main one was the T slot on the left had a casting flash (bump) that blocked the
the T slot when the throttle was at idle, would'nt even let it close all the way. Closed on the left and .060 T slot on the right. Also found a hairline crack on that side where the IMS is.
