-   -   Tunnel ram bogs (http://www.hotrodders.com/forum/tunnel-ram-bogs-232025.html)
Fang16 04-20-2013 01:56 PM
Tunnel ram bogs
I've got a bad bog off idle when nailing it. Tried it at 1100 and 1500 RPM and no difference. Idles at 1100 in gear. 2 x 750 1407 Edelbrocks. Stock jets and springs, accelerator pump in 3rd (top) hole, 3 inch spacers between carbs and breathers/scoop. Timing is by way of a MSD 6AL-2 programmable. 20 degree retard for start, 36 degrees full in at 1000 RPM. MSD pro-billet locked out.
355 CI
11:1
Comp cams XR292R
Duration @ .050 254 intake 260 exhaust
Lift .582 .588
Edelbrock TR1YX tunnel ram 2 x 750 Edelbrocks
Ported double hump 2.02/1.60 3891462 64cc heads
700R4/3500 stall
3.90:1 ford 9"
Race weight 3257
80% Street/ 20% strip car
thinwhiteduke 04-20-2013 03:17 PM
You got one too many 750's
Duke
NEW INTERIORS 04-20-2013 03:27 PM
Way to much carb's..1500 cfm's..:pain: For A 355..
vinniekq2 04-20-2013 03:33 PM
2x 750 is fine,lol.
Fang16 04-20-2013 03:38 PM
Originally Posted by vinniekq2 (Post 1668594)
2x 750 is fine,lol.
Yes it is. Now if I can just get the bog out it. Really woke it up from the 2 x 450 Holleys. If I could only get some info on getting the bog out. Lot of good info here but couldn't find an answer.
NEW INTERIORS 04-20-2013 03:46 PM
It's fine but you have a problem with it...:rolleyes:
If you think it woke it up,,, Take the tunnel ram off and put one 750 on it and see just how much it will really wake it up... Most motor's like your run it's best with one 750 on it... what does that tell you..
Fang16 04-20-2013 03:49 PM
It's all in the tune. I'm competent a good tuner well have something worthwhile to say.
NEW INTERIORS 04-20-2013 03:51 PM
Sound's like you already have it all figured out.. Have fun..:D
Fang16 04-20-2013 04:08 PM
What's that on ur t-bucket?
NEW INTERIORS 04-20-2013 04:14 PM
1 Attachment(s)
First off..That's not my t-bucket,, I only built it... And they are not 750's...
Now I think your's is on your willy's...
Now I did own one of them..:mwink: Mine had a 468,BBC, 400 trans,3000 stall, 9'' ford,4;56 gears, Msd, And no dead spot..AT ALL..;)
This was mine..:D
http://www.hotrodders.com/forum/atta...1&d=1366496097
Fang16 04-20-2013 04:22 PM
I guess the 113 more inches and Holly's made the difference. hee hee Nice looking Willys. A little low in the front though. lol
NEW INTERIORS 04-20-2013 04:31 PM
NOPE !!! Just two well done 450's...:D
Fang16 04-20-2013 04:55 PM
I had 450's on it but it ran out of steam around 4300. Now it hits 7k in a heart beat.
NOlowrider 04-20-2013 05:50 PM
Looks like you have everything I would recommend (stall, locked out timing, ect).
What type of linkage? Don't say pregressive.
Have you tried a 50cc acc pump?
Do this happen from a rolling start?
33Willys77 04-20-2013 06:20 PM
Well, all this talk and no advice?? Ok, you need to figure out if its too much air, or too much gas causing the bog. You have a big space to fill. You could try bigger squirters. Was any weight removed from the rear butterflys (the ones that open with vacuum, not the throttle plates)? When you stab the throttle, it bogs, but hit the throttle a few times at that time and see if it takes off or gets worse. If it seems to kind of like it better, it may need a bigger shot of fuel. You may benefit from taking off the spacers - if you need/want the scoop height, put spacers above the carbs to raise it. Might be worth a try.
