Tunnel ram bogs - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2013, 01:56 PM
Fang16's Avatar
Last journal entry: Project change
Tunnel ram bogs
I've got a bad bog off idle when nailing it. Tried it at 1100 and 1500 RPM and no difference. Idles at 1100 in gear. 2 x 750 1407 Edelbrocks. Stock jets and springs, accelerator pump in 3rd (top) hole, 3 inch spacers between carbs and breathers/scoop. Timing is by way of a MSD 6AL-2 programmable. 20 degree retard for start, 36 degrees full in at 1000 RPM. MSD pro-billet locked out.
355 CI
11:1
Comp cams XR292R
Duration @ .050 254 intake 260 exhaust
Lift .582 .588
Edelbrock TR1YX tunnel ram 2 x 750 Edelbrocks
Ported double hump 2.02/1.60 3891462 64cc heads
700R4/3500 stall
3.90:1 ford 9"
Race weight 3257
80% Street/ 20% strip car
Old 04-20-2013, 03:17 PM
thinwhiteduke's Avatar
Living In The Past
You got one too many 750's
Duke
Old 04-20-2013, 03:27 PM
life is a temporary assignment
Way to much carb's..1500 cfm's.. For A 355..
Old 04-20-2013, 03:33 PM
vinniekq2's Avatar
2x 750 is fine,lol.
Old 04-20-2013, 03:38 PM
Fang16's Avatar
Originally Posted by vinniekq2 View Post
2x 750 is fine,lol.
Yes it is. Now if I can just get the bog out it. Really woke it up from the 2 x 450 Holleys. If I could only get some info on getting the bog out. Lot of good info here but couldn't find an answer.
Old 04-20-2013, 03:46 PM
It's fine but you have a problem with it...
If you think it woke it up,,, Take the tunnel ram off and put one 750 on it and see just how much it will really wake it up... Most motor's like your run it's best with one 750 on it... what does that tell you..
Old 04-20-2013, 03:49 PM
Fang16's Avatar
It's all in the tune. I'm competent a good tuner well have something worthwhile to say.
Old 04-20-2013, 03:51 PM
Sound's like you already have it all figured out.. Have fun..
Old 04-20-2013, 04:08 PM
Fang16's Avatar
What's that on ur t-bucket?
Old 04-20-2013, 04:14 PM
First off..That's not my t-bucket,, I only built it... And they are not 750's...
Now I think your's is on your willy's...
Now I did own one of them.. Mine had a 468,BBC, 400 trans,3000 stall, 9'' ford,4;56 gears, Msd, And no dead spot..AT ALL..
This was mine..
Old 04-20-2013, 04:22 PM
Fang16's Avatar
I guess the 113 more inches and Holly's made the difference. hee hee Nice looking Willys. A little low in the front though. lol
Old 04-20-2013, 04:31 PM
NOPE !!! Just two well done 450's...
Old 04-20-2013, 04:55 PM
Fang16's Avatar
I had 450's on it but it ran out of steam around 4300. Now it hits 7k in a heart beat.
Old 04-20-2013, 05:50 PM
NOlowrider's Avatar
US Navy-Retired
Looks like you have everything I would recommend (stall, locked out timing, ect).
What type of linkage? Don't say pregressive.
Have you tried a 50cc acc pump?
Do this happen from a rolling start?
Old 04-20-2013, 06:20 PM
33Willys77's Avatar
Well, all this talk and no advice?? Ok, you need to figure out if its too much air, or too much gas causing the bog. You have a big space to fill. You could try bigger squirters. Was any weight removed from the rear butterflys (the ones that open with vacuum, not the throttle plates)? When you stab the throttle, it bogs, but hit the throttle a few times at that time and see if it takes off or gets worse. If it seems to kind of like it better, it may need a bigger shot of fuel. You may benefit from taking off the spacers - if you need/want the scoop height, put spacers above the carbs to raise it. Might be worth a try.
To tunnel ram or not to tunnel ram maverickmechanic13 Engine 107 03-04-2012 07:33 PM
tunnel ram blazinlow Engine 3 05-21-2011 06:31 AM
sbf hi ram tunnel ram 72fordlb Engine 9 04-13-2009 04:15 PM
Tunnel ram? HemmiGremmie Engine 5 09-02-2003 05:40 PM
a tunnel ram? jboxcar818 Engine 2 12-11-2002 09:04 PM
