Tunnel Ram on a chevy 305? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2008, 07:46 PM
Hey im pretty new to chevy small blocks and my set up is a 73 c/10 longbed with a 305 that was just rebuilt. It also has a granny 4 speed tranny so really low gears. I want to basically put a new cam and lifters and rockers and intake and carbs and exhaust plus msd ignition on it. I really like the tunnel ram look and by reading up on it it seems like a pretty good deal except im not sure of it since my gears are so low i dont think my RPMs go up really high. I have an edelbrock performer 750 cfm carb on it right now and it floods the engine and I cant get it to run good without running rich. But hey my real question is in your opinion what would be a good set up for a small block chevy with the things im gonna do to it? cam,intake,carb, ect. Its basically going to be my rat rod nothing to fancy just as much power as I can get from my engine.
Old 04-06-2008, 07:51 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
You need to up the cubes or decrease your cfms. 750 Edelbrock can be large even for a 350 and is definitely too big for a 305. Your tunnel ram idea would be better on a 350 or 383.
Old 04-06-2008, 07:52 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
You'll feel more power out of that truck by just keeping your performer manifold, putting a 600 (or smaller) CFM carb on it and doing a cam swap (I'd consider this last) to an RV cam. A tunnel ram, if you're actually looking for a drivable truck, is pretty much completely out of the question. You don't have the cubes or the heads to bother with it. You can get a nice running motor for low bucks in your case, however.
I would also hold off on the MSD ignition if you've already got an HEI unit. That's plenty for this application.
I'm assuming this was a stock rebuild, was it?
K
Old 04-06-2008, 08:02 PM
Its got pretty much stock everything except for the carb. This truck was given to me and I dont really care much about the money except I dont really want to rebuild the bottom end and bore it out since it was just done lol. soo Im basically looking for the most power out of it that I can buy and not have to machine.
Old 04-06-2008, 09:39 PM
327NUT's Avatar
As said above, with a STOCK 305, 327, 350 a tunnel ram would be the worst thing you could do for a streeter. You can make the 305 perform with the right combination of parts. Do a search for 305 build up, its been gone over quite a bit.
Old 04-06-2008, 10:21 PM
Welcome to Hotrodders Post pics when you can and if you need to restore your grille this will help Repairing, Rejuvenating & Restoring a Plastic Grille
Shane
Old 04-06-2008, 10:44 PM
Ok ok haha sooo I guess the tunnel ram isnt going to work without putting a lot into the motor when I should just get a bbc if I want alot of power. so the next thing I guess is...what would be the best stuff I can shove in there that would give me some good horses out of it? AND I know theres a big difference in heads on the 305 and the 350s soo can I just put 350 heads on a 305 without changing the bore or the stroke And will that give me the better flow im wanting for more horses?
Old 04-07-2008, 09:24 AM
if you put 350 heads on a 305, it'll have extremly low compresion.
which heads do you have now? take off a valve cover and there is some numbers cast on the head somewheres
Old 04-07-2008, 09:59 AM
It has stock 305 heads... guess I should just put a mild cam in it and a performer intake with some headers for flow and call it good. Thanks for everyones help!
Old 04-07-2008, 10:05 AM
there are more then 1 "stock 305" heads. some are much better then others. they're usually dirt cheap to buy since nobody wants them
Old 04-07-2008, 10:17 AM
what about 327 heads cuz I have a 327 laying around here... and I have no idea what the numbers are or what the engine is pulled from.
Old 04-07-2008, 10:18 AM
327 heads might be 64cc or 76cc. either way it will drop the compression. stock 305 heads are between 52 and 60 cc
Old 04-07-2008, 10:28 AM
dang guess theres nothing i can do really huh?
Old 04-07-2008, 10:44 AM
you could bolt on better 305 heads
and a mild cam
and headers and a decent dual exhaust
scrap the msd idea and use a decent HEI unit
use a 500-600 cfm carb with vacuum secondaries
Old 04-07-2008, 02:31 PM
bullheimer's Avatar
NEVER use credit cards!
someone sells redun 305 heads and passes them off as being good for any sbc, i don't remember who tho. they are dirt cheap and all redone tho.
if you have the same granny low 4 speed trans i do, and it takes forever and a day to shift from 2nd to 3rd gear i would say JUNK the damned thing and getta REAL 4 speed for a car. they are dirt cheap for a working saginaw. only muncies (yours is a muncie 465?) M-20-1-2 are too much money for used ones. i would stick with the 305 as is, with a performer, cam, headers and a car trans. leave the gears for later. i would then start machine work on the 327. buy parts you will use on the 327 later. good call on the el'cheapo HEI. the one i got from summit for like $130 runs circles around my tired old (15year old) Unilite
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Tunnel Ram 327 1970CamARo(327) Engine 57 09-16-2008 08:24 AM
96 chevy 305 vortec heads on 350 block badriand Engine 6 02-20-2006 07:45 AM
Effects of compression ratio on tunnel ram throttle response Adrenaline_Fiend Engine 4 09-10-2003 01:39 PM
85 chevy 305 heads on an 89 TBI chevy 350? jazzguitar Engine 4 11-03-2002 04:11 AM
