Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tunnel Ram I designed
  #34 (permalink)
Old 03-03-2012, 10:56 AM
matts37chev's Avatar
matts37chev matts37chev is offline
& matts38chev
Last journal entry: Try again
kind of a hi-jack--food for thought
Originally Posted by ap72
Why not divide it into "8 plenums" and just use it with carbs that have equal venturis and a mechanical linkage (along with 2 accelerator pumps and 4 corner idle etc). Essentially you would create an IR system from 2 4bbl holleys, which could REALLY make an improvement down low. Tuning would be easier than it is right now as well since you could tune each cylinder individually and there wouldn't be an uneven mix of cylinder pairings.
you could also try altering your cam timing on each lobe to compensate for the firing order, but that would take more R&D and $$$ than I think you would want to invest for a street application.
I have read this thread before, and I just reread it, and it really got me thinkng
what would happen if I only used the bottom half of my T-ram and a carb spacer to mount the throttle body EFI ????
would this make better throttle response?
or am I just trying to re-invent the wheel
