Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tunnel Ram I designed
  #36 (permalink)
Old 03-03-2012, 03:51 PM
L79vette L79vette is offline
Originally Posted by matts37chev
I have read this thread before, and I just reread it, and it really got me thinkng
what would happen if I only used the bottom half of my T-ram and a carb spacer to mount the throttle body EFI ????
would this make better throttle response?
or am I just trying to re-invent the wheel
With your TBI, you should be better off mounting them on the normal plenum. With TBI, you get excellent atomization and distribution, even with the large plenum.
Atomization and distribution is the key to driveability - that is why I divided up the plenum. With carburetors, you need velocity through the venturis to get the metering to be correct at low RPM. But with TBI, the computer calculates the injector pulse width based on MAP and RPM - you don't need velocity through the throttle body to meter the fuel.
All that said, I have not built what you are talking about, so if you do it, let us know how it works out!
