Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tunnel Ram I designed
  #39 (permalink)
Old 03-04-2012, 03:06 PM
Valkyrie5.7's Avatar
Valkyrie5.7 Valkyrie5.7 is offline
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
Originally Posted by L79vette
In comparison to port injection, yes. But TBI atomizes way better than a carburetor, especially at low airflow. Fuel injection does not depend on airflow through the venturi to draw out and atomize the fuel, so the atomization is equally good across the whole range of airflow.
Here is a link to a statement by Jim McFarland, who knows as much about mixture quality as any living human:
http://www.maxchevy.com/columns/mcfa...farland-1.html
Port injection runs at 50-60psi fuel rail pressure, while TBI runs at 12-15psi. Plus with the injector next to and pointed directly at the intake valve, port injection does not give the fuel the opportunity to drop out of suspension while moving through the manifold. So with port injection you can set things up so the fuel evaporates at just the right time.
That makes sense. Thank you for the clarification and the reading material
