Tunnel ram install - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2010, 08:42 AM
Tunnel ram install
Bought a used intake. Its was installed on a show car some years ago and has been sold once and now in my hands. It was not installed on anything but the show car. It looks like it has never been fired or any fuel ran through it. My question is the angle of the top plenum. I just assumed that the rear of the intake would be taller than the front giving that normally the engine has a slight angle while sitting in the car and your intake has a slight angle on the top to balance it out allowing the carb to sit level. Am I wrong here, or could someone have put the top plenum on backwords?? also, there is a small threaded hole on the back of the top plenum. Is this correct and whats it used for?? Sorry, newbee here.
Old 08-17-2010, 08:56 AM
MRTS33's Avatar
33 Pontiac 3W Sport Coupe
Some have a spacer plate angled underneth the carb that bolts to the plenum. The hole on top of plenum is a vacum port for power brakes and such I would imagine.
Old 08-17-2010, 10:03 AM
lg1969's Avatar
Google "Tunnel Ram 406"
Some Tunnel Ram manifold are set up in an angle for the carbs because the motor sits on an angle. The rear part of the motor sits lower than the front. Giving an allusion The front carb is sitting higher then the rear and they are both the same level. If you install a spacer on the rear carb to level it off you will cause uneven fuel distribution.
Old 08-17-2010, 12:47 PM
So with the manifold sitting on the bench, when I measure the front where the carb will sit, it is higher than the spot where the rear carb will sit. Wouldnt it be the other way around seeing as most motors tilt to the back??
Old 08-17-2010, 01:06 PM
lg1969's Avatar
you can add spacer between the air cleaner for the rear carb.
Or use two air filters. Holley does sales seprate air filters. They triangle shape. Stay away from the bug eye sponge filter. It will dry and break away and get sucked in. If backfire it will catch on fire. There are T-rams that are set up flat instead of an angle for the carbs. If you lay the t-ram manifold on a flat surface they will be even only angled slightly foward.
Old 08-17-2010, 01:17 PM
ericnova72's Avatar
More for Less Racer
Could be that someone has put the top on backwards, if you could post a pic it would clear a lot of things up.
Old 08-17-2010, 01:28 PM
I was wondering if someone has but it on backwards.. I will try and post a pic when I get home from work. Thanks for all the input guys. Would much rather install it once and not have to tear it apart on the car.
Old 08-17-2010, 01:55 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
In most applications, the rear carb will be a little higher than the front, due to the 'rake' of the engine in the vehicle.
On the TR top shown below, the orientation is obvious- it's made for a pair of spreadbore carbs- so the "front" and "rear" are easily discernible.
Old 08-17-2010, 03:21 PM
NOlowrider's Avatar
US Navy-Retired
It is possible to put the plenum on backwards. Trust me I did it.
I have a Weiand T-ram (now removed for a 6-71 ) and shortly after I installed it I noticed that my "bug catcher" was tilted way up in the front.
Removed the plenum and turned it around and it was fine after that. So, yes it is possible. Just be careful because there is a gasket between the two, and you can't just run down to the local store and get one.
Mine doesn't have a hole drilled in it though. Maybe the PO tapped it for a vacuum source.
Old 08-17-2010, 04:21 PM
I will try and post the pics I just took. Looks like it is just over 9" in the rear and just over 9.5" in the front. Also note the threaded hole in the rear..
ID:	47531   Click image for larger version
ID:	47532   Click image for larger version
ID:	47533   Click image for larger version
Old 08-18-2010, 06:03 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Prolly just a case of the custom vehicle's "posture" required the tilt of the top to be "backwards" from what is seen normally.
I would plug the hole in the top w/a polished or anodised flush-mounted plug of some sort and use another port for manifold vacuum for the brake booster, vac. modulator, etc.
If the gasket tears, run down to the parts store for a roll of FelPro gasket material to make a fresh gasket from.
Old 08-18-2010, 07:09 AM
NOlowrider's Avatar
US Navy-Retired
yea, guess that would work too.
Old 08-18-2010, 07:18 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Beats using a pizza box top- which I did years ago for a Bultaco side cover gasket.
Old 08-18-2010, 07:19 AM
65 Imp SS's Avatar
Yes there is an angle put into the intakes due to the auto manufacturers put approx 3* angle slope on engine placement. That intake looks like a holley hi ram #1984 http://www.holley.com/1984.asp can you confirm this?
You will notice the backside (distributor hole side) that the back carb mounting base is thicker then the front, hence to achive rake requirement. Also the intake manufacturers do make gaskets for between the top and base. If it is the holley you will see it listed in parts and kits on attached link.
That is a nice polish job on intake is that going in what looks like a 56 chev in background?
Steven
Old 08-18-2010, 07:48 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
From Jegs:
Notice the way the top’s mounted? The intake is a Weiand… “just say why-and”, BTW. I guess Holley owns them now.
This is Summit's image:
Tunnel Ram Nitrous Fogger Location 454headache Hotrodding Basics 1 05-06-2010 09:55 AM
Tunnel Ram Carb Vacuum Connections Yegster Engine 4 03-14-2010 01:12 PM
tunnel ram w/ 2 450 cfm or 1 single 850 cmf what do you think is beter?? tiresmoke55 Engine 12 08-28-2006 09:15 PM
tunnel ram manifold Bad Rat Engine 2 08-12-2004 04:21 PM
Tunnel Ram 68stang_99 Interior 3 08-16-2002 03:29 AM
