tunnel ram linkage help needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2007, 10:39 AM
pal pal is offline
after much thought i have decided to keep my holley 4160 450cfm carbs mounted in-line on my wiend t-ram sbc. i would like to set up with progressive linkage, that way i have the option of going 1:1 if i want. i cant find a source for complete kit that includes parts needed for intake manifold mounting arms. all the kits i find are just the carb to carb parts. any ideas on where to find good quality parts or complete kit? thanks.
Old 03-10-2007, 10:45 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Summit has linkages
Old 03-10-2007, 11:02 AM
pal pal is offline
been looking at summit. seems they do not have complete or high quality unless you are using the side-mount system.
Old 03-10-2007, 11:38 AM
powerrodsmike's Avatar
Wiki Edits: 161
try jegs then
http://www.jegs.com/webapp/wcs/store...10313_-1_10267
Seems to me that mr gasket has individual parts to make up your own linkages.
I thought offy did too, but I couldn't find it on the website.
Weiand has some in line linkage kits that might work.
Later, mikey
BE different....ACT normal.
tunnel ram set up advice/opinions needed please pal Engine 22 03-22-2013 04:53 PM
Tunnel Ram on 383 Stroker Nitromethane Engine 6 02-25-2011 09:06 PM
Tunnel Ram information xntrik Engine 79 08-17-2008 03:15 PM
tunnel ram on the street henny496 Engine 10 10-03-2006 06:59 PM
Big Block Tunnel Ram 2X4 Question 74NovaRat Engine 12 01-28-2005 02:22 PM
