Tunnel ram questions......... - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2008, 07:45 PM
I have a Chevelle with a stock 350 2 bbl. on and was wondering what (if anything) would have to be done to a stock motor to run a tunnel ram and 2 4bbl's. Or would I be better off swapping out the 350 for a 454 and running the tunnel ram/2-4's setup on that? Any advice??
Old 08-19-2008, 07:49 PM
If you had some really small 370 cfm vacuum secondary carbs you could get away with it.
It would look awesome, but not necessarily run better than a 600 on a Performer intake.
Old 08-19-2008, 07:59 PM
DeathRattle's Avatar
Some Punk Kid
Your gonna be lookin for the smallest carbs that you find for a stock 350.
Old 08-19-2008, 08:23 PM
tunnel rams work with motors that are designed to have horse power that starts at what 1800 rpms or higher .
so you will fall on take offs from dead stop , unless you stall it at 2000 rpms .
eric302's Avatar
Why be normal?
What gears are in the rear? Auto trans with stock converter? Do you want it for show or go? What part of WI are you from? I have a 51 Chev. 350 with a Weiand tunnel ram.
Old 08-19-2008, 08:46 PM
I'm from LaCrosse, Eric (approx. 4 hours from you). Is the engine complete? How much are you asking for it? The rear is an open with 373 gears but I'm looking for a posi.
Old 08-19-2008, 08:57 PM
eric302's Avatar
Why be normal?
The 350 is in my daughters 51 Chev. Turbo 400 with 2800 stall, 411 posi, it's a 79 motor with 480/230 cam and stock heads, 500 cfm edelbrock carbs, it goes pretty good but you need to do a little planning If you want to go the tunnel ram route. It's not for sale now but just an example of what can be done.
Old 08-19-2008, 09:25 PM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
What year, what engine?
I would say with the information given you would need to up the compression, get better heads and exhaust first thing. Tunnel rams need the ability to flow for them to be of any use.
Then comes transmission and rear gearing... tunnel rams like rpm's...
Old 08-20-2008, 12:25 AM
AmericanPackMule's Avatar
Last journal entry: Adolessent J.R.
Chev. Tunnel Ram...
"HOW MUCH MONEY IS IN ESCROW?" How fast / dependable do you want the car? Do you have a 2nd. Transportation?
Old 08-20-2008, 06:03 PM
Lonestar's Avatar
Ok, look here...
http://myspacetv.com/index.cfm?fusea...deoid=40914987
This is my 327 powered "Bird. I am running a Weiand tunnel ram. I went with a single 4 setup but guess how much of the entire car is stock????
If you answered with anything more than the exterior sheet metal, seats and steering wheel you're wrong...
Single 4 rams are a pain to tune due to fuel distribution issues, especially at idle; but once you get it right it will idle at a decent rpm and is managable on the street. I know a lot of people with dual setups but they usually have to make compromises along the way.
The problem with a stock setup is that airflow velocity in a stock compression / cammed engine is usually compromised to the point that you have to fudge the carb tuning in such a way that you maybe can get it to run right at either low rpm's or high rpm's... but not both at the same time.
I know there are people out there that have managed to make it work, but they are few and far between... it really comes down to simple physics.
If you're just looking for the "cool" factor and are not interested in the true potential of the ram then stick it on there and run a pair of the smallest carbs you can find... and when I say small I mean throttle bore diameter... the smaller diameter bore the higher the airflow velocity...
Old 08-21-2008, 02:53 PM
lg1969's Avatar
Google "Tunnel Ram 406"
Statutory grape, you can run a pair of holley 390cfm #8007. change the power valve to a single stage 6.5 PV and 57 jets on the primary. Because the carbs do run a little lean. If you look at lg1969 photo album. This is what am running. 355 10:5 compression, 2.02 heads, Crane fireball cam, Holley 390 with Edlebrock street tunnel ram, turbo 350 with 3000 10" converter, and 410 gears. I can smoke the tires right off the line with no bog
tunnel ram question? sseymour18 Engine 11 09-18-2006 09:54 PM
tunnel ram w/ 2 450 cfm or 1 single 850 cmf what do you think is beter?? tiresmoke55 Engine 12 08-28-2006 10:15 PM
tunnel ram with 2-4's / lean 347mustang Engine 3 10-28-2005 05:39 PM
single vs. dual tunnel ram upstand2 Engine 5 06-28-2005 05:30 AM
Big Block Tunnel Ram 2X4 Question 74NovaRat Engine 12 01-28-2005 02:22 PM
