Tunnel Ram on a sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2008, 11:24 PM
Tunnel Ram on a sbc
Still deciding whats gonna sit on top of my 383 stroker. So far its goin good the block checked out and machining has begun. I was wondering if tunnel rams kill as much tourqe as people say they do? Also has anyone else built a tunnel rammed 383, what kind of combination are you running and what kind of power are you getting? I'm looking at either a Dart or Weiand tunnel ram my heads are a set of trick flow 170's with some port work and 2.02/1.60 valves and the cam will be a comp roller either xr270 or xr 274. Any suggestions greatly apreciated. thanks, Jake
Old 06-18-2008, 04:40 AM
i have a 383 with a weiand tunnelram in my 87 S10 i use a comp cam 292hyd.basicly stock heads (202 and 160 vavles installed) till i can get new ones i have a 3500 stall converter i put in a eagle stocker kit for the bottom end. the engine idles at 1300 any lower then 1000rpm and it stalls, or spits sputters. but I built my manly for cruse nights and shows tunnel rams look alsome, thats for sure and i have no complents with mine. pics of my s10 while it was flat black now in the shop getting sprayed HOK pravo purple metal flake. all depends what u wanna do with your ride i guess. go with the tunnelram
Old 06-18-2008, 12:27 PM
smrat, what kind of power are you making with that thing. Ever had it on a dyno? What kind of cam and gears are you running? Does it cruise down theroad allright, my car is only a once a week driver not much more. The weiand tunnel ram is rated at 2500-8000 rpm i believe. And i think its the one i would like to use. Plus it would look so good with a blower style scoop out the hood of my car
Old 06-18-2008, 04:30 PM
lg1969's Avatar
Google "Tunnel Ram 406"
Just be careful how large the carburetors are. For the street I use a pair of 390cfm Holley carb. in my chevelle. I would change the primary jets to 57
and a 6.5 single stage power valve. I used a blue pump cam and set it for #2 setting. With two carburetors you will get 780cfm. You will get good low end torque and strong midrange and top end. I do not recommend 450cfm for the street unless you are racing it at the tracks.
Old 06-18-2008, 06:22 PM
The weiand manifold is available in a single carb application so i was thinking of going that route with either a 750 or 850 double pumper holley.
[IMG]C:\Documents and Settings\Home\My Documents\My Pictures[/IMG]
well i cant figure out how to post pictures
Old 06-18-2008, 07:12 PM
tubbedz's Avatar
Jake
You may be able to make it work. I recently had a tunnel ram combo on my street 355ci Chevy and it had torque as soon as you get on the gas through 7000rpm. It had 10:1 pistons, 461 fuelie heads ported with 2.02/1.60, 3000rpm stall, and 4.88 gears. The carbs were two 600cfm vacuum secondaries with 29" x 18.5" tires and the cam was a solid Isky grind with 254' duration. It idled at 900rpm with a mean cam lope and the low end would pull right off idle. The only problem I ran into was tuning the 600's...it took awhile. Jetting, squirters, pump cams and secondary activation took awhile to sort but if you're good with Holley's it shouldn't be a problem. In the end I added two NOS plates and stayed on the conservative side with 150 shot total. That engine would scream with rpm's !! I have since sold that motor to a circle track racer who buzzes the rpm's every weekend.
Old 06-19-2008, 12:07 AM
Well i've alreay got 4.10 gears in the car right now and will probably stay there unless i get around to putting in a ford 9 inch then i can go to what ever the motor wants. I'll be running a 3500 rpm stall for shure if i decide to stay with th automatic and a trans bake or line loc. Compression is gonna be 10 maybe 10.5 if i can get away with it on aluminum heads? Eventually it'll have large 1 3/4 headers and 4 inch exhaust out the side. So that leaves the cam? What do you guys think? definatly roller, Would like to be around the 500/500 mark if possible so my 77 camaro will realy boogie down the strip. Im also planning on taking her to a dyno for final tuning then ill know what i really got Thanks so far, keep the great advice comming
Old 06-19-2008, 01:03 PM
Anyone got any cam sugestions?
Old 06-19-2008, 03:46 PM
life is a temporary assignment
I ran two 600 on my 350,Did OK,But then I went to two 450's And it came alive!!! Two 450 is 900 cfm's Most good motors run very good at about 750 to 850.
Old 06-19-2008, 05:20 PM
What about a single 850, do tunnel rams run good with single carbs i know weiand offers theres with a single carb top?
Old 06-19-2008, 09:00 PM
ericnova72's Avatar
More for Less Racer
Tunnel ram
Single four-barrel tops for tunnel rams are known to be about the worst intake set-up you can bolt together The best engine builder's in the country can't make them perform, mixture distribution is terrible, the four inner cylinders are pig rich and the four outers are lean.
The only set-up that works is a custom built sheetmetal ram that actually looks more like a 10" tall single plane intake.
Why they even still sell the single four tops is beyond me, maybe it's a case of giving the customer what they want despite the fact that it is about 6 steps in the wrong direction
Tunnel Ram is a waste of time unless you are targeting the additional power that they can make in the 6500-8500 rpm range, and it won't be with one of the typical "street rams" that clutter up Ebay.
The four Tunnel Rams that actually work are--
Edelbrock Pro Ram and Pro Ram II ( both out of production)
Weiand Team G Super Ram (designed by Grumpy Jenkins, out of production)
Edelbrock Victor Ram
Holley Pro Dominator Tunnel Ram
Go to the dragstrip and see if anybody fast is running a street tunnel ram, I can virtually gaurantee you won't find one
Old 06-20-2008, 10:29 AM
lg1969's Avatar
My tunnel ram setup
This is what my using in my 69 chevelle 355cid edlebrock TR1X and a pair of Holley 390cfm. On the secondaries, I'm using metering blocks and change from a single feed to a dual feed setup. I've got a 11:1 406sbc that I'm replacing and using AFR heads with the same setup I'm using on the 355.
Old 06-20-2008, 09:22 PM
i have a 3500 B&M stall converter, 456 rear gears.i never tryed it on a dyno. i built it mostly for cruse nights and shows. it runs great but likes to drink gas too. sometimes i cheat and loosen the rear carb linkage srcew so the rear carb doesnt work till i need it. i dont notice any difference w/o the rear carb hooked up .if you use the wiend tunnel ram, you have to you use a small dist. mine is a MSD mech advance, i forget what the part number is now, call Jegs or Summit they can tell you.
Old 06-21-2008, 04:41 AM
IG1969, who did you take the manifold to for polishing?
Old 06-21-2008, 05:48 AM
Just this pas month a nice young man with a 355 S10 was having issue with his 'set-up', a 2 x 4 Tunnel Ram. Don't get me wrong, the thing was quick, but he listened and dumped his tunnel ram for a single Dominator. Night and day difference with driveability and performance.
tunnel ram set up advice/opinions needed please pal Engine 22 03-22-2013 04:53 PM
SBC tunnel ram w/2x450 holleys problems rodnok1 Engine 7 10-12-2010 04:54 PM
Tunnel Ram information xntrik Engine 79 08-17-2008 03:15 PM
Tunnel ram carb selection baddbob Engine 2 07-09-2007 09:05 AM
Big Block Tunnel Ram 2X4 Question 74NovaRat Engine 12 01-28-2005 02:22 PM
