Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - tunnel ram on the street
Old 10-01-2006, 12:06 PM
Bumpstick's Avatar
Bumpstick Bumpstick is offline
Hammer and a torch
If they are the Holley 450`s then for sure it would be fine even on the street... Also even with the 660`s that most tunnel rams came with it should be drivable with some tuning... You did not mention what type of trans...? Auto...? If so what stall which will affect the combo also... If its a manual then its really no problem... While the tunnel ram is not the most desired setup for the street it does attract alot of attention even now... Nothing like seeing it sticking through the hood and a couple of carbs on top with velocity stacks...
Still make`em quiver at the red lights...
