Tunnel ram on a street bbc - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-10-2011, 02:53 PM
lg1969's Avatar
Google "Tunnel Ram 406"
Mine starts up on a dime. I use the choke setup on the rear carb., only.
Just google tunnel ram 406 and you see what I mean.
  #17 (permalink)
Old 06-11-2011, 02:21 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by BBCRedline
I have been thinking about running a weiand tunnel ram I have on my bbc but not sure which 4150 carbs to get?
Have you also given any thought to the big hole in the hood of your Camaro that's gonna be needed?
  #18 (permalink)
Old 06-12-2011, 03:52 PM
BBCRedline's Avatar
I have thought of the cutting the hood thing. I have a lift off hood Harwood hood, so I can run the thing and see if I like it before the opening has to be made. I was just on the phone this last week talking to Joe Sherman about the whole tunnel ram thing. He likes them and says they can be a magical 100 hp add on. I will not be buying any demon carbs, basically because they are out of business and I owned one once and that was enough.
  #19 (permalink)
Old 06-12-2011, 04:41 PM
Banned User
He said 100hp? Under what specific conditions?
  #20 (permalink)
Old 06-12-2011, 05:34 PM
BBCRedline's Avatar
This is based on my 540 with afr 335 cnc heads at 720 or so hp without it. I bolt on the tunnel ram and I could see up to 100 hp gain. Maybe 75 or 105 or who knows. I will have to dyno it both ways.
  #21 (permalink)
Old 05-11-2014, 07:44 PM
BBCRedline's Avatar
This is a follow up on the tunnel ram that I bought and motor combo. The engine ended up being a 540 with AFR 335 heads at 10 to 1 compression. Edelbrock tunnel ram with 2-750 QF carbs works awesome with timing locked out at 34*. As far as things changed on the carbs I removed the jet extensions and idle feed jets are 30.
  #22 (permalink)
Old 05-12-2014, 08:38 AM
Just noticed an ad for the Street Demon in july '14 Hotrod (pg 141), had a little faint Holley logo just above the Street Demon name...
Street Tunnel Ram BOWTIE JIM Engine 41 12-18-2011 06:30 PM
Tunnel Rams For The Street? BottleBaby Engine 23 10-13-2010 07:33 PM
Compression on street tunnel ram 383 Engine 7 11-25-2007 12:27 AM
tunnel ram on the street henny496 Engine 10 10-03-2006 05:59 PM
Street Tunnel Ram 68stang_99 Engine 10 08-16-2002 04:27 AM
