Tunnel Ram/Vacuum Secondaries/Cam/Torque Converter - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 09-05-2010, 07:42 PM
Yegster's Avatar
The pump and the pickup were new in the rebuild - I remember is being one of those "it's only $75 for everything - cheap insurance. I can't believe it was the part that brought the engine down. Just seems like such a no brainer to secure something like this in such a high vibration enviroment.
As for the TC, I'm really glad you have brought this up. I was thinking 2400 all along, even knowing the "rules" about light/heavy cars. I didn't want something that felt like a CVT in a small car - always revving like it is supposed to, but not going like you think it should be.
This will be a real interesting conversation with a converter builder - and again, I'm sure they are going to want to know what rear axle ratio I'm going to use. I like the idea of the 3:42 and the resulting low rpm on the freeway, and I guess if we nail the performance of the engine, it will take off just as fast since I can't nail it now without execessive wheelspin.
I'm sure that is going to be another $1,000 for the gear change by the time that is done...
Good stuff!!!
Thanks!
  #47 (permalink)
Old 09-05-2010, 11:04 PM
Yegster's Avatar
Love it! I detail cars for extra cash...just need to do more!!!
I can't believe you noticed threads on bolts! You are just amazing!
Let me change subjects a bit. I'm reading a lot of articles on 396 builds and all of them note issues with the original heads (that I don't have), and problems with cylinder walls/interchangibility with 454 cranks, etc.
If it comes down to a cheaper alternative to mate my 454 Hi Perf heads with a new 454 short block (pick cam, pistons, etc.), isn't that the way to go? As far as I know, everything I have is going to bolt up - brackets, mounts, etc.
Is the only reason I would consider a 396, just because it is what the previous owner built the car with?
A 454 certainly should be more common place and hopefully less expensive than a two year production 396.
Of course this all will play out based on what is salvagable, but I don't think there is that much hp/torque to be gained with the 454 crank. I could be wrong there but 30 or 40 hp isn't going to be something I'm really going to notice missing or having.
Thoughts?
  #48 (permalink)
Old 09-06-2010, 02:27 AM
Yegster's Avatar
Cool website the guy put together to honor the car and the man. Maybe I should fly you out here for the unveiling...
Noticed that same video on Joe's website when I looked him up yesterday. Must be proud of that one!
In a couple of weeks I hope to have an assessment of the damage. We'll see what happens from there. In the meantime, plenty of companies to call and inquire about parts to get a head start on things.
And about that power comment...yep, have all I want to take off...but greedy to scare myself some more after that...then I'll be too chicken to use it...
Thanks again!
  #49 (permalink)
Old 09-19-2010, 11:57 AM
Yegster's Avatar
F-Bird, Eric, others,
Still no job, but did good news in that the speed shop is going to take care of most, if not all of the repair expense. In about 10 days, I'll have the engine at the shop and then we can see what the damage is.
In the meantime, I have been in touch with TCI for the converter and Comp for their recommendations on a cam.
TCI's numbers on what my car is doing, seems to confirm I have a 3,000 rpm converter in the car now. Replacing it with a Street Fighter might not change a thing. The consensus for now is to leave the converter there and check out the performance with the new cam, timing settings that F Bird recommended, etc. There may be enough of a shift in torque, that the idle creep issue is minimized.
Not really wanting to pull the engine or trans later, but saving $500 right now is a good thing.
Can't figure out how to make columns so each of the cams are listed below.
Hoping to go for the roller if the total cost isn't too prohibitive.
Magnum 270
Duration @ .50 224/224
Lobe lift .510/.510
Lobe Center Angle 110
Non Roller
Duration @ .50 234/244
Lobe lift .564/.566
Lobe Center Angle 112
Roller
Duration @ .50 236/242
Lobe lift .547/.566
F Bird - in a prior post you were looking for a 114. Any issue with a 112? Advantages that a 114 brings?
That's it for now. Need to get busy on an muffler solution before the pipes get sent to Jet Hot for coating. Starting on that later today. Need to let this engine breathe a bit - and see what difference it makes.
Thanks for any comments and recommendations!!!
SBC stroker project, small budget jankinnu Engine 63 11-21-2010 11:53 PM
TCI Stall Converter - Blown SB 68NovaSS Transmission - Rearend 10 09-09-2008 01:42 PM
Tunnel Ram information xntrik Engine 79 08-17-2008 03:15 PM
Help tuning 383 for street use strokey Engine 29 04-11-2008 06:51 PM
Big Block Tunnel Ram 2X4 Question 74NovaRat Engine 12 01-28-2005 02:22 PM
