Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tunnel rams are cooool
Old 01-02-2013, 06:21 PM
bygddy bygddy is offline
Proud LOSER
So, here's what I have done....flipped, flopped, supercharged or not..383 or not....yada yada yada....
Summit rebuild kit, flat top hypers, 60 over, already ordered.
Then this, Weiand tunnel ram, 2 600 holleys
This I now have.
Then.......
Block is getting zero decked.
Turns out my 1150$ ik200's are actually 1400$ when I called to order....so decided on the Dart shp 200's. They will get some porting and clean up.
Cam will be Lunati solid, 247/256, 525/540, 106lsa, 100icl, pn#30120521
Converter is still the 3000 stall (yes I know a 3500+ would be better.
Gears will be 486
Long tube headers, 3" exhaust, undecided on mufflers.
Compression should be 10.5, quench is 0.041
Bottom end is ordered already, intake and carbs I have, converter I have.
So that's it....opinions?...no fights, gladly listen....yes Gary, even you lol....truce.
Will be running no hood, checkerboard painted firewall, gold moroso valve covers, Mr gasket velocity stacks....even bright yellow accel wires! Ghetto 70's retro with 80's cheesy pro street.....I love it.
