Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tunnel rams are cooool
Old 01-02-2013, 08:49 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
look at the valve lash , do the math its the same net lift.
if you ordered a rebuild kit from summit why did you not look into these
other parts at the same time. @ summit.?
You seem all over the planet and seem to be being pulled to what ever is stuck under your nose
like a used tunnel ram....
