Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tunnel rams are cooool
  #28 (permalink)
Old 01-02-2013, 09:34 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
The lunati cam in the anvil motor is Lunati #40119
The other parts of the anvil article are found here
Index To The Anvil Series - Engine Buildup - Hot Rod Magazine
The cam is shown in the 3rd article.
The Isky cross reference cam is Isky 201549.
if the dart heads come in with cheap valve springs you had best replace them with the right stuff.
Both these cams are serious cams and need serious springs. DO no use 1.6 rockers.
These are not for the faint at heart.
YOU MUST check VTP clearance with both these cams. You may have to touch up the valve reliefs if the block is 0decked.
you'd best discuss this and the details with your machinst.
