Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tunnel rams are cooool
  #60 (permalink)
Old 01-04-2013, 07:30 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Do you have a dial caliper on hand there?
want you to measure the compression height on those.
Tell me the pin hole diameter and the distance from the pin hole to the piston top
using the dial caliper.
CH='s measured distance from pin hole edge to the piston top + (half of the pin hole diameter)
