And then there's the price! Bettter plan on a glass Willys coupe, as I bought and built my whole Austin for less than a bare '40-'41 Willys coupe shell would cost! But the '55 Chevy is a big car, and a bit more affordable. You could get a running, driving '55 Chevy for what a Willys body costs! |
.. Those old Willys were made right here at Willys/Overland plant... still a lot of them around here... as are Jeep Wranglers made here and until last August, the Jeep Liberty (sometimes still called a 'Cherokee' in foreign countries that don't like the word 'Liberty') and, up until a year or so ago, the Dodge Nitro version of it...
.. Here's a slick, handy online calculator for RPM vs tire size vs rear ratio vs tranny gears vs MPH (click 'clear right' button before doing anything). Gives a great spreadsheet of info: http://www.F-Body.org/gears .. One of my current projects is a SBC 405", MoTown 220 cc alum. heads, Summit #1105 224/234 hyd. flat cam... it's on its 3rd or 4th set of heads and intakes and hasn't even run yet... LOL! . Another is Ford 351"M/400 block 2bbl. getting 400 crank, KB domed pistons, 214/224 cam, and 4bbl. carb. for an F150.. Last edited by BuzzLOL; 01-05-2013 at 11:14 PM. |
I love the chevy II's myself. I got a line on a few rust buckets but looking for a clean one. |
Picking up cam today, bought a comp 294s with lifters, $125 bucks still in the box!
248/248 525/525 Should work well I hope, may go 1.6 for more lift.... Need heads and hardware and I should be ready to get this show on the road! After some good advice and some follow up reaserch its going to be the summit house brand 200cc /64cc Or a set of pro-filer's. So.....in summary, 360ci 10.5 comp .041 quench Comp 294s solid lifter can 200cc/64cc alum heads Weiand tunnel ram 2 600 VS holley's Msd ready to run dist/blaster 2 coil Long tube 1 5/8 headers 3" exhaust, likely to dynomax race bullets. TH350, shift kit, 3000 stall Ford 9" 488 gears Looking for 12:50's and a fun weekend beater... Wish this snow would go away lol |
I just got a set of procomps and they look pretty dam good. 210cc intakes and all pix in my profile. But hardware was all custom setup by machine shop i fpund on ebay. Got heads roller rocker stud girdle guide plate screw in heavy studs and head bolts all for 990 bucks. I can send you the link if you want. Pix of procomps http://www.hotrodders.com/forum/memb...omp+heads.html Summit brand is probably procomp as well. Or some other cheap casting. If you want cheap and good go with world of products motown heads they are cheap and do the job and avaible in 210cc intake runners. Edelbrock also makes a cheap head these days. |
Yah, for all the negativity I have heard about the procomps, a now know a couple guys using them from skip white's and im told he has his own hardware locally installed. One just made big power on the dyno using the procomp 210's. And he says the heads looked really nice, no surprises....$650 bucks! I don't wanna turn this into a political thread about buy USA etc,but was surprised to hear how good they were, the first few generations of them were a disaster and always hit and miss on quality, but it appears that just isn't the case so much. That being said, until there is some more info on them available I will likely stick wit the summits's.....1049$, 210 runners, and using the flow charts from brodix they should work very well......course I will likely screw them up with a little port work lol....but hey.... Oh and my cam, love it, jegs double shipped it to a guy I know,when he opened his order, there were 2 of them complete with lifters lol. So i bought the spare! |
Well you cant go wrong with brodix.
Are procomps made in china. Its not really a product i would think would be made in china. Now canada sounds right but probably us made. They are not stamped made in china that i can remember. I will look again. Good score on the cam. 200cc heads a ram and 294 solid it should run well. |
what is the icl and lda for that cam? make sure the valves are good quality.just port the exhaust side a little to make up for a non split.
If that car only runs 12.5s Ill drive back east and kick the tires off of it |
Should be a snarly little motor hoepefully. |
Yep read up on them and was going to buy bare casting or edel e streets or something but found these worked up with all the right stuff. Ready to go. I do plan to run a large victor intake at some point so wanted as much head as i could afford. Have you actually seen in writing from procomp these are made in china. Cause china does not really do chevy car parts for the most part. And usally large lumps of aluinum come from canada or other countries with aluminum resources. Now i beleive you but have not seen it but everyone on the net screams china junk but china does not have much advantages for casting large aluminum parta like other countries do. I also would not put it past the aussies. But these could be made anywhere. All you need is a small foundry a large haas and a good patten. These look alot like edelbrocks i was wondering if they were a sister brand of one of the big three. Since most of the time pattens are hardest thing to come buy. I would like to know if these are a stolen patten. But would not be suprised if one of the big three makes these dirt cheap and doesnt want there name on them. |
I met Ed Iskenderian at the local community college last year, and he wanted to get behind the wheel and sit in the Austin. He had to go around to the passenger side and slide across. A bit too rotund to slip between the wheel and the door frame, and he's not all that big!
| Tunnel Rams For The Street? | BottleBaby | Engine | 23 | 10-13-2010 07:33 PM |
| can tunnel rams go on a stock engine? | d&c repairs it all | Engine | 4 | 01-01-2009 06:33 PM |
| 2 1/2 Rams horns. | 49willard | Engine | 6 | 08-06-2008 07:13 PM |
| Air rams | Augusto | Suspension - Brakes - Steering | 4 | 03-31-2006 07:29 AM |
| Pics of old tunnel rams. | Jmark | Engine | 6 | 10-10-2003 01:57 PM |
