Originally Posted by BOBCRMAN@aol.com
That setup would never pass tech at a track. That stuff you are using for fuel line is "beverage tubing" made to run colas' and budwiper thru..
Seen it for many years. Threw them all out.. Disaster in the making Not on my watch..
NHRA 2010 Rulebook:
General Regulations, 1:5 Fuel Systems, Lines....
"All non-OEM fuel lines (including gauge and/or data recorder lines) must be metallic, steel-braided or NHRA-accepted "woven or woven-pushlock". A maximum of 12 inches total, front to rear, of non-metallic or non-steel braided hose is permitted for connection purposes only."
12 inches total means a 2 inch piece here, a 2 inch piece there, used for connecting hard lines and not totalling more than 12 inches of hose, all added up together, on the entire car.
You fellows don't think about these things, but if that beverage hose ruptures and the hot headers light off the mixture and there are any holes in the firewall..........
Another of the things you don't think about, for instance. If your battery is in the front, stock location and is not secured to the car. You don't think much about it, because you figure the battery will be there forever. And it will, as long as the shiny side if up. But what happens when you blow a tire at 90 MPH and flip the car. The hood comes off and the battery comes out. Now, we have a 40 pound missile going 90 MPH. Do you think that might do some damage????? What if your kids are in the trajectory?????
Us tech inspectors have to foresee the worst possible case and prepare the race car and the racer for it to prevent personal injury and/or death.
