tunning my 78 460/429 dove heads
at what dgr should i set the timming? i've got it @ 20 adv now and experincing a ping on excel and it wants to diesel when i shut it down.
If you are talking 20 degrees initial timing, I'd say that's a little much. Around 8 would be better, at least a place to try and see if it likes it or not.
What is your idle speed? If you are dieseling after you shut off the key I would first suspect a higher idle than what it should be. Stock idle is around 700. Also, maybe check for vacuum leaks. Mm |
| tunning a new engine | CARGUY | Engine | 17 | 03-29-2010 08:44 PM |
| Need some advice tunning 350 sbc HEI | eric32 | Engine | 5 | 07-12-2009 06:36 PM |
| Dyno tunning | flaming79 | Hotrodders' Lounge | 2 | 01-27-2006 09:04 PM |
| Dove rocker arms.....>>>> | bigbadbowtie | Engine | 2 | 12-15-2005 06:41 AM |
| Dove heads? | 53fordguy | Suspension - Brakes - Steering | 3 | 09-20-2004 04:14 PM |
