Turbo - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2011, 08:46 PM
Turbo
Ok guys probably and odd one for this site, but thought I'd start here first. I'm looking at trading my quad for a 93 Mazda low rider pickup, now he told me its a mx6 motor with a turbo off a 16 valve cummins, he claims it has 20 pounds boost, and 300hp. Now I think 220 maybe more realistic, I'm more concerned on wether the internals could handle that. Has anyone had experience with this? Any input helpfull
Old 10-23-2011, 08:25 AM
In theroy, if you add 20 psi of boost to a 127hp engine then it should make 300hp. Not a big number and very possible.
The question is what is his doing for engine management? (fuel and ignition timing control) If you add more air with boost then the engine needs to get more fuel somehow and use less timing as the cylinder pressure goes up.
And a intercooler would be a must with 20 psi of boost.
I'm not experienced with mazda engines, but I know old 2.8 liter z engines will easily handle 400hp at the crank with boost.
Old 10-23-2011, 08:43 AM
Both the mx6 and ford probe gt had that engine turbocharged from the factory. I'm guessing he did the complete swap wiring, computer and all? I'm pretty sure that turbo is too big, It would take forever to get to 20lbs. That engine is pretty beefy and can handle 300hp all day long as long as it's tuned properly. you would be better off with a super 60 or GT35 turbo and even they may be on the big side?
Old 10-23-2011, 01:08 PM
Thank you guys, I'm going to look at it today.
Old 10-23-2011, 01:40 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
I'm at work now and can't find the address (it's a private website, not a forum) where a guy swapped a 2.3L turbo into a an old base model fox body mustang and all of the modifications he made to it just junkyarding. Not very technical as he basically learns by trial and error, but there's some good tips and tricks on the cheap in it. Towards the end before he abandoned the site, he was prepping a DOHC volvo head to swap on it and some other different stuff.
When I get home I'll try to remember to look up the bookmark.
Old 10-23-2011, 10:13 PM
Turbo, really?
Sounds like B.S. Walk away!
Old 10-24-2011, 06:40 AM
Banned
It probably takes a while to spool but with 20psi 300hp is easily doable. Take it for a ride, you can feel a big difference between 120hp and 300hp.
Old 10-24-2011, 06:52 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I wouldn't even consider it w/o a leak down test.
Old 10-24-2011, 07:10 AM
Banned
That's a good idea. Also, check the oil, coolant, and plugs. Good maintenance goes a long way.
Old 10-24-2011, 12:54 PM
Wiki Edits: 15
well, I guess the site is down, I'm not surprised, it was pretty old. The address was:
http://msvorinich.itgo.com/oldindex/oldindex.html
turbo 350 and turbo 350c riley81GMC Transmission - Rearend 6 12-12-2009 08:07 PM
Thrush Turbo or Dynomax Super Turbo? henkelphoto Engine 3 08-24-2006 11:46 PM
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 12:40 AM
Turbo 350,Turbo 400,700R4,Or Muncie 4 Speed nightrain_rod Transmission - Rearend 2 04-18-2003 12:35 PM
400 turbo to 350 turbo problems mikeweyman Transmission - Rearend 2 04-02-2003 05:58 PM
