Turbo on 3.8 Cutlass?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2003, 07:31 AM
Post Turbo on 3.8 Cutlass??
My 85 cutlass only has a v6 231 3.8L in it now. Buick Grand nationals also had 3.8L. Although those cars came with turbochargers on them. Would it be possible for me to take a turbo from a GN and bolt it on to my cutlass? If so how easy would it be. Also would this be a better choice then putting a V8 into it. Thanks for the input.
Old 05-24-2003, 08:51 AM
BOBCRMAN@aol.com's Avatar
Post
if you had a complete,similar year, turbo Buick the swap would be just a parts change but it gets more complicated with different computers and induction systems. Small block chevys are bolt ins with the correct frame mount.
Old 05-24-2003, 10:19 PM
Nos's Avatar
Nos Nos is offline
Post
id just drop a blown oldmobile 455 big block.. for about $2000-$3000 ... almost the same as a superchager/turbo-charger maybe a little faster .. i think that wouldd be better .. well thats my 2 cents
Nos
N|O|S
Old 05-25-2003, 05:51 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
I gotta agree with Bob. If you want to do the swap, you want to get the entire engine and ecu. It can certainly be done without, but the complicaiton level goes out of site. Tuning efi to run with a turbocharger when it was not designed to do so is very tricky and usually requires an upgraded unit. The factory buicks also came with a knock sensor setup which is a big plus. Good luck.
Chris
Old 05-25-2003, 06:57 AM
Post
Yea i kinda like the idea about the 455!! But do u think i would be better off putting a SBC in it like a 350. If so how much do u think it would cost to pick up a decent one?
Old 05-25-2003, 11:11 AM
Nos's Avatar
Nos Nos is offline
Post
you can buy a used 350 out of the classifieds.. for about $300-$400 and rebuild it for like $200-$300 more for a kit i think? not sure may cost more or less for the kit..
or you can go to
www.summitracing.com and get a complete engine already built
here is a compltet 350 with 410 horsepower www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=4241&prmenbr=361
hers another page with a rebuild kit
<a href="http://store.summitracing.com/default.asp?target=search.asp&type=bykeyword&searc htype=both&part=350+rebuild+kit]http://store.summitracing.com/default.asp?target=search.asp&typ e=bykeyword&searchtype=both&part=350+rebuild+kit[/URL]
i got my 350 for $300 and took it to a machine shop had them bore it 0.060 over new pistons.. there building me heads.. they hottaked my blocked polished my crank.. new oil pump .. cleand my intake.. everything on my engine except my crank is going to be new it will cost me about $1500 to get it running SWEET! i need to get a new cam.. but it should be pushin 450+ hosepower.. my engine will be like its brandspankin new!
but its also about how much money your willing to spend!
hope this helps...
Nos
[ May 25, 2003: Message edited by: Nos ]
[ May 25, 2003: Message edited by: Nos ]</p>
N|O|S
