Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Turbo 350 to a 1992 305 engine
Old 01-16-2013, 07:29 PM
gearheadslife gearheadslife is offline
Banned
count the teeth it be 153 or 168
you'll need the matching starter for the 305 plate..
your old 350 might have a stagard starter mounting
the other is straight across bolt pattern..
most likely your 305 has starter mounting holes straight across in a line..
if your 350 starter isn't you'll need to get one..
or, change the starter noses
