-   -   Turbo 350 to a 1992 305 engine (http://www.hotrodders.com/forum/turbo-350-1992-305-engine-228474.html)
carnutbilly 01-16-2013 06:03 PM
I have a 1975 350 engine & Turbo 350 in my hot rod, when I when to install a 1992 305 engine the flex plate from the 350 engine would not fit the 305 engine.
Is there any way to install a Turbo 350 trans. to a 1992 305 engine?
thanks bill
gearheadslife 01-16-2013 06:08 PM
yes get a flex plate for a 1 piece rear main seal..
any auto house can get you one..
1992 camaro 305 flexplate..
gearheadslife 01-16-2013 06:13 PM
More Information for ATP Z165
carnutbill 01-16-2013 06:24 PM
The flex plate on the 350 engine is about 14" diameter & the flex plate on the 305 engine is about 13" diameter. Is the Camaro flex plate 14" diameter?
thanks bill
gearheadslife 01-16-2013 06:29 PM
count the teeth it be 153 or 168
you'll need the matching starter for the 305 plate..
your old 350 might have a stagard starter mounting
the other is straight across bolt pattern..
most likely your 305 has starter mounting holes straight across in a line..
if your 350 starter isn't you'll need to get one..
or, change the starter noses
