Turbo 350 to a 1992 305 engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2013, 06:03 PM
I have a 1975 350 engine & Turbo 350 in my hot rod, when I when to install a 1992 305 engine the flex plate from the 350 engine would not fit the 305 engine.
Is there any way to install a Turbo 350 trans. to a 1992 305 engine?
thanks bill
Old 01-16-2013, 06:08 PM
Banned
yes get a flex plate for a 1 piece rear main seal..
any auto house can get you one..
1992 camaro 305 flexplate..
Old 01-16-2013, 06:13 PM
Banned
More Information for ATP Z165
Old 01-16-2013, 06:24 PM
The flex plate on the 350 engine is about 14" diameter & the flex plate on the 305 engine is about 13" diameter. Is the Camaro flex plate 14" diameter?
thanks bill
Old 01-16-2013, 06:29 PM
Banned
count the teeth it be 153 or 168
you'll need the matching starter for the 305 plate..
your old 350 might have a stagard starter mounting
the other is straight across bolt pattern..
most likely your 305 has starter mounting holes straight across in a line..
if your 350 starter isn't you'll need to get one..
or, change the starter noses
1992 chevy 350 good engine or bad? 1996thunderchicken Engine 5 02-12-2012 01:24 AM
1992 chevy 350 good engine or bad? 1996thunderchicken Engine 8 02-11-2012 07:39 PM
Wich heads do you recommand for OFFROADING -305 or 350 on a 350 engine? offroader9 Engine 1 04-07-2010 01:07 AM
1992 camaro 305 BEETLEJUICE Introduce Yourself 1 04-07-2007 02:56 PM
How to tell if engine is a 350 not a 305 Meka Engine 14 06-16-2004 05:07 PM
