Turbo 350, 1st and reverse gears only - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2008, 11:16 AM
Being new to the forum, but familiar with forum etiquette, I checked best I could to find this answer before asking my first ever question on this board. I have a '68 chevy pickup, 2WD, 327 engine, TH350 tranny. The other day I was getting on the interstate and accelerated hard to pass another vehicle. All of a sudden there was nothing except high RPM's. I was able to get to the shoulder without incident (surprising considering I-70 in central Missouri) and determined I only have first and reverse. I tried shifting through the gears and still no go. Previous to this I did have a slight drip of tranny fluid, but the fluid level seems to be OK on the dip stick. Also, it is clear and does not smell burned. Any ideas? Thanks!
Old 06-20-2008, 05:08 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
I think it would either be a broken sprag or clutch
pack, either way it needs to come out & taken
apart.
Rich
Old 06-20-2008, 10:52 PM
Crosley's Avatar
Wiki Edits: 1659
Since 1st and reverse gears work... I would check the detent cable if the trans has one. See if the cable is free to move in & out of the outer housing = not stickking in WOT position.
Check the vacuum source / hose at the modulator on the trans.
Then pop off the governor cover and check the plastic drive gear= they break.
Gov is under the round press on steel cover near back end of case side. Check for clearance to re-install the cover first. The cover comes off easy , goes back on with difficulty if there is little room to work with
Lost all but 1st... Turbo 400 Bumpstick Transmission - Rearend 3 04-22-2007 09:29 PM
turbo 350 diagnosis help drchevy4x4 Transmission - Rearend 9 03-29-2006 05:20 AM
turbo 350 trans not shifting out of 1st phillip24 Transmission - Rearend 3 02-25-2004 11:34 AM
turbo 400 won't shift out of 1st gpeak Transmission - Rearend 7 10-12-2003 08:52 PM
turbo 350 trans aint workin now..why?! ilikerocks Transmission - Rearend 3 11-07-2002 05:34 PM
