Welcome Rook! Good site here, and you'll pick up plenty of info.
First, a TH350 is a three speed, not four, as is the TH400. A TH350 can be rebuilt to handle plenty of HP/torque, and takes less power to run. I've seen estimates that HP drop through a 350 is around 30 vs 50 and up for a 400, so using a 350 is the way to go for a lot of folks. With a "normal" stroker small block, you're probably looking at around 400 ft. lbs. torque, and a good tranny shop can make a TH350 live at that level. Also, it depends on what the car has now. A "short tail" TH350 is a direct replacement for a Powerglide; the TH 400 needs a different rear crossmember and shorter driveshaft. With the way gas prices are going, you may want to consider a 4 speed (OD) automatic, like the 200 R4 or 700 R4. Each of those has it's own set of requirements, but generally the 200 R4 is a more direct fit and stronger. Eric |
By the way, depending on where you are in jersey, I can hook you up with a guy that rebuilds 8.5 inch 10-bolts fairly cheap, probably cheaper than you can pay someone to put a posi and gears in the 8.2 (if it is the original rear).
| 700r4 Swap to a Turbo 350 | humanVr4 | Transmission - Rearend | 23 | 08-02-2004 07:48 AM |
| SWITCHING TO A 400 TH from a 350 TH | 70SPORT | Transmission - Rearend | 6 | 06-23-2004 12:53 AM |
| A 350 from a 400 block and 327 crank. | M&M CUSTOM | Engine | 10 | 05-30-2004 03:49 AM |
| Broken 400 SBC flexplate with a 350 block... | realsquash | Engine | 5 | 04-20-2004 11:23 AM |
| turbo 350 | Tissue | Engine | 3 | 04-09-2004 07:05 PM |
