turbo 350 4wd unit to 2wd? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2010, 08:21 AM
diamond mike's Avatar
throw me under the bus agian
was wondering, can a guy take a 4wd turbo 350 tranny ( remove the transfer case , leaving a flat end on tranny ) and bolt a long shaft piece for a 2wd? does that work?
Old 03-22-2010, 09:20 AM
ericnova72's Avatar
More for Less Racer
No, the trans has to be completly stripped down to replace the output shaft. You can't just throw a 2wd tailhousing on it, the length and spline of the shaft is different.
Old 03-22-2010, 09:33 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
It's unfortunately not that simple, IIRC.
I believe you need to swap the output shaft and add the correct housing and speedo gears to make it happen. The swap requires the tranny come all the way apart except for the VB.
EDIT- I didn't just get treed, I got forest-ed! lol Sorry 'bout that. Got sidetracked and should have looked first before posting.
Old 03-22-2010, 04:14 PM
yeah, guess i was wishing on that one...oh well, off to find a replacement...mike
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Need help for transmission yoke for turbo 350 eric32 Transmission - Rearend 8 04-28-2009 08:58 PM
350 turbo vs 400 turbo stoplight king Transmission - Rearend 3 04-23-2009 04:57 AM
Turbo 350 & 550 HP BB Chevy leejoy Transmission - Rearend 4 12-06-2007 09:56 PM
Turbo 350 1980 Malibu Transmission - Rearend 14 07-27-2003 04:24 PM
