Turbo 350 & 550 HP BB Chevy
Hi
Ok, I finished the motor, got the subframe connectors on and have a 3.08 gear posi rear end with stock suspension. It's a 72 Nova with a 550 HP BB Chevy. The trans is a stock Turbo 350 with a new shift kit. I need to start planning now for this next fall's work on the car. Should I keep the Turbo 350 and rebuild it - stronger, or put in a Turbo 400................I"ve never rebuilt a automatic trans..........
Before you say "trade it in for a Turbo 400" remember the turbo 400 is heavier, longer (have to shorten drive shaft) and the crossmember has to be relocated and possibly replaced with a different one. that's a lot of extra work and more money that I don't want to spend and do if it's not necessary. Right now the Turbo 350 is holding up but perhaps not for long. After this recent engine rebuild (and the upcoming larger carb) I won't be surprised if it destroys itself under a load taking off from the line. I've seen performance professionally rebuilt Turbo 350's advertised for up to 500+ HP. I know very little about this and need several opinions. By the way I have standard street tires in the back, little wider than stock but not your "hook up" racing slicks. So if your thinking this car is going to pull the front end off, it won't because it smoke the tires instead. that works in my favor as far as not destroying the trans right?
thanks for your reply.
Lee
