TURBO 350 or 700R4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2008, 02:58 AM
700r= junk
omy opinon on 700r is very simple there not good if your doing anything but sitting ive put 5 in my 85 chevy and the tv cable was allways set right so i know it wasnt that this one over drive is going out of sum ive had have been abused sum not this one that is in it now has less than 500 miles on it and ive havent even gotin my foot in it very much so im going to switch to a 350 turbo or 400
Old 06-24-2008, 06:45 AM
Crosley's Avatar
Wiki Edits: 1659
Welcome to Hotrodders.
I split off this post from the thread you posted to. It was a 5 year old thread you posted to.
A 700/4L60 needs a proper build to last any length of time. There are many upgrades for them and can be expensive to build.
Good luck on your project.
