turbo 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2011, 03:40 PM
inquiring_mind2's Avatar
a shade tree mechanic
turbo 350
I have a turbo 350 in my jeep I use for mudd bogging. I started it up and noticed it was low on fluid. I put a quart in it to bring it up to the full line. I took it out and ran it up and down the alley to see how it was working. I shifted it to drive then 2nd then first. in drive it was slow getting going the same with second but in 1st and reverse it would spin the tires. but when I stopped and put it in park fluid was coming out the top of the dipstick. I checked the vent and it isn't clogged. I don't run tranny lines. I have a line making it a continuous flow. I only run it for about 10 min then I am done. so my question is are my clutches bad or is the stall bad?? or maybe is it something else???
Old 09-22-2011, 05:30 PM
or could it be a spring in the valve body??
turbo 350 to turbo 700r? diamond mike Transmission - Rearend 5 04-28-2010 10:34 PM
Thrush Turbo or Dynomax Super Turbo? henkelphoto Engine 3 08-24-2006 11:46 PM
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 12:40 AM
Turbo 350,Turbo 400,700R4,Or Muncie 4 Speed nightrain_rod Transmission - Rearend 2 04-18-2003 12:35 PM
400 turbo to 350 turbo problems mikeweyman Transmission - Rearend 2 04-02-2003 05:58 PM
