Tristen... first you should have posted this to the "Transmission" board. As far as the leak. There is a oring and gasket that seal the front pump to the case. Many times I have seen the pump bolts left loose causing a leak. You can try to see if they are loose using a long 1/2" wrench. If the bolts are not loose, it is likely from the pump seal and bushing. If the bushing is worn, the seal cannot keep it from leaking. I have also seen the spring in the seal get knocked out on installation. that will cause a leak.
Good Luck
