Turbo 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2002, 07:43 PM
Post Turbo 350
My tranny was already rebuilt once. But now its leaking fluid from the driveshaft weephole why is that. I have plenty of grease inside.
Please help does it have anytihng to do with the clicking noise my tranny makes when its warmed up. It also does it when the car is is not moving is that possible?
Old 09-25-2002, 04:33 PM
dklong's Avatar
Post
where do you mean by the drive shaft weep hole. where is the noise coming from on your trans front or back. if it is from the front it could be your torque converter or your trans pump. when you installed the torque converter did you turn and shove the torque in all the way? the torque converter has 2 notches cut in it , for the trans pump. if you didn't shove it in all the way, the converter can put pressure on the pump and destroy it. this probable your noise! to find out if it is your problem , unbolt your torque converter and see if you can turn it . if not ( the pump may all ready be damaged ) remove trans and check notches on the pump by removing the converter and looking into the front of the trans where the converter was , you should see 2 notches oppitsite of each other. make sure there are good and square to each other, by putting in the torque in wrong you usally destroy the pump . to fix this replace trans pump.
Old 09-25-2002, 07:58 PM
Post
Thank you very much for you reply. The leak is from the rear where the drive shaft goes into the tranny the middle of the yoke has a weep hole where fluid is leaking out of the tranny into the driveshaft and out the hole. what does this mean. I will check the torque converter is it a hard job?
Old 09-26-2002, 06:17 AM
Post
When the torque converter is installed correctly you shouldn't be able to slide your hand between the converter and front pump housing.
Old 09-26-2002, 06:41 PM
Post
to fix that hole in the yoke u pull the driveshaft out clean inside the yoke with brake cleaner take a beer cap with the top of the beer cap facing inthe yoke push it to the bottom the yoke until silicone comes out the hole,forgot to tell to put silicone on top of the beer cap canadian beer caps fit perfect in 350 yokes
Old 09-27-2002, 06:31 AM
Post
whatis the purpose of the hole will plugging it damage anyhting. I thought it a blow out safety so you dont blow your tranny is this true?
thanks for your reply
Old 09-29-2002, 04:29 PM
Post
The hole is there to let air out but this type of yolk is supposed to have a sleeve with an o ring pressed onto the output shaft, the end of the yolk (inside the tailhousing) fits into this sleeve to seal it.
Sounds like you have no sleeve so you need a yolk with no hole in it, just plug the hole as described above.
[ September 29, 2002: Message edited by: Jason ]</p>
