turbo 350 detent cable replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-07-2005, 08:19 PM
How do I replace the detent cable on my turbo 350 transmission. Do I need to drop the transmission pan?
Old 12-07-2005, 08:25 PM
no you don't need to you can reconnect it through the hole in the case and then reattach it to the engine linkage
Old 12-07-2005, 08:32 PM
Thanks for the quick reply. One more question. How do I unhook the cable. The cable feels like it has tension on it. Is there a trick to releasing the tension and reconnecting the new cable?
Thanks
henryg
Old 12-07-2005, 08:42 PM
Siggy_Freud's Avatar
The cable is held in the tranny by a bolt if I remember right. It hooks to a loop inside, but the cable housing is held by a bolt or lever. Just pull on it and unhook it from the carb, and then detach it from the tranny.
Bringing history and technology together.
Old 12-07-2005, 08:50 PM
Thanks. I will give it a try tomorrow night.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 01:18 PM
Turbo 350 Chevy radracer43 Engine 2 09-24-2005 01:59 PM
350 Turbo Trans greywulf Transmission - Rearend 3 03-29-2005 10:17 PM
stuck detent (kickdown cable) dawg Transmission - Rearend 2 09-20-2004 10:58 AM
350 turbo in vette problem mikeweyman Engine 2 03-26-2003 08:00 PM
