Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - turbo 350 diagnosis help
Old 03-28-2006, 08:02 PM
Chazmac Chazmac is offline
The low roller clutch is broken or the rear planetary flange is broken where is splines into the low roller clutch inner race. Manual 1st works because the low/reverse clutch holds in manual low (and reverse) only. Shift to 2 and it releases (part of why 2nd is so hard)
Sorry, pull it out. Can't fix it in the car......
