Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - turbo 350 diagnosis help
Old 03-28-2006, 09:32 PM
drchevy4x4 drchevy4x4 is offline
Originally Posted by Chazmac
The low roller clutch is broken or the rear planetary flange is broken where is splines into the low roller clutch inner race. Manual 1st works because the low/reverse clutch holds in manual low (and reverse) only. Shift to 2 and it releases (part of why 2nd is so hard)
Sorry, pull it out. Can't fix it in the car......
Will the transmission explode if my son drives it like it is for a while....funds are low right now and he really needs his car to get back and forth to work. We have 2 cores that I can rebuild later (summer) but we need to get all the parts to do it.
the transmission was never useed by us before the shiftkit install.
