Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - turbo 350 diagnosis help
Old 03-29-2006, 01:34 AM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Wiki Edits: 9
Chazmac AND Crosley together in a thread to answer this, I am thinking from what Chazmac didn't cover in his detailed enough answer basically says between the lines that it needs removed and you are chugging along with a countdown timer that will either stick or run fast, basically saying it's only a metter of time before the transmission "tells" you that it quit.
