Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - turbo 350 diagnosis help
Old 03-29-2006, 06:20 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by drchevy4x4
Thanks Crosley I saw in his profile that Chazmac has a lot of experience, was just hoping that he would be able to tell me if he thought the tranny will blow up if he drives it or if he can drive it by manually shifting as it seems to be working ok this way...thanks to all responders
Would you drive a car when the engine is on it's last leg? Or mayb real low oil pressure?
There is a problem with the trans and it will not get better or go away. It will chew it's self up slowly as you drive it.
On the flip side , you may be a lucky person and the trans could drive for another year
