Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Turbo 350 Doesn't Shift In Drive (must manual)
Old 10-25-2008, 06:33 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
is intake manifold vacuum hooked up to the transmission modulator?
have you checked the vacuum at the modulator?
It is possible the plastic gear on the governor is broken... a round press on cover is where the governor is hidden.
