Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Turbo 350 Driveline Question
Old 03-14-2011, 05:26 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
Should be very little wiggle if any at all.
Is the Trans Yoke engaging enough of the Tran's Output Shaft splines?
With the Rear Pinion Yoke disconnected you should be able to slide the Driveshaft into the Trans about 3/4". This is measured at ride height, suspensioned loaded.
