Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Turbo 350 Driveline Question
Old 03-14-2011, 06:08 PM
karfever's Avatar
karfever karfever is offline
38 Chevy Coupe Ram Jet 502
Originally Posted by SSedan64
Should be very little wiggle if any at all.
Is the Trans Yoke engaging enough of the Tran's Output Shaft splines?
With the Rear Pinion Yoke disconnected you should be able to slide the Driveshaft into the Trans about 3/4". This is measured at ride height, suspensioned loaded.
More information. The trans is a TCI unit with 2800 miles on it. The yoke goes into the tailhousing about 3 1/2 inches, about 1 1/4 remaining at ride hieght, suspension loaded. The yoke only slides about 1/4 inch while driving, throught the suspension travel.
Yes I have some wiggle at the yoke with the suspension loaded and drive shaft installed. BTW, the drive shaft is a new custom PST aluminum
