Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Turbo 350 Driveline Question
Old 03-16-2011, 01:53 AM
SSedan64's Avatar
SSedan64 SSedan64 is offline
The Angle is Ok, Min. is 1*, Max. is about 5*.
I would think TCI would use a new Output Shaft bushing and your new Driveshaft should be balanced correctly.
This is from Denny's>> http://www.dennysdriveshaft.com/freq....html#faq_id10 according to them 3/4" is Min. & more than 1" isn't needed. I wouldn't think the extra 1/4" would be causing the wiggle/play but I could be wrong. You could slide it in more & see if it tightens up the play, if not the Bushing may be worn. If it's easily moved & the wiggle/play easily felt somethings worn.
I'm not sure what the clearance/tolerance is for the Yoke to Bushing.
I have one of these>> http://cgi.ebay.com/ebaymotors/Auto-...item1e61d70446 it removes & installs the Bushing without removing the Tailhousing. Real handy for 2004R Trans, as it doesn't have a removable Tailhousing.
