Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Turbo 350 Driveline Question
Old 03-16-2011, 04:22 AM
NvrGrwUp NvrGrwUp is offline
The trans and the rear end should be at the same angle. Not + and - of each other, they should be in the same plane. If one is at +3 and the other at -3 that is off by 6, hope that it is just the way you read your angle finder.
