Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Turbo 350 Driveline Question
Old 03-16-2011, 06:00 AM
karfever's Avatar
karfever karfever is offline
38 Chevy Coupe Ram Jet 502
Originally Posted by NvrGrwUp
The trans and the rear end should be at the same angle. Not + and - of each other, they should be in the same plane. If one is at +3 and the other at -3 that is off by 6, hope that it is just the way you read your angle finder.
You are correct, so let me say this a different way. The engine/trans is 'down 3 degrees, the rear 'up' 3 degrees, on the same plane.
