Turbo 350 fluid lines leaking is there better way to plumb lines? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2009, 02:37 PM
heathj1's Avatar
Which way to the swap meet??
I have a g body malibu with a turbo 350 with a small block. When I got the car tranny lines were a mess so I bought 2 60 inch sticks of 5/16 line bent them up with a bender from napa. Where the lines go into trans the bottom one always leaks. Before I rip into in again is there a easier way to run tranny cooling lines? Something easier to work with. Wont fuel line hose get soft and leak?
Thanks
Old 11-08-2009, 03:25 PM
boatbob2
trans line leaking...
Hi,did you use teflon tape on the fittings? if not,do so.
Old 11-08-2009, 04:53 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Thanks
You need to use a flexible hose from the tranny to the frame rail where it connects to the hard line unless you are running solid motor mounts. I would run braided lines but I have used fuel line with no problems.
Old 11-08-2009, 06:25 PM
Cape Cod Bob's Avatar
Whereu use rubber to tube, flare the tube a little and make sure there are no sharp edges. The flare will help keep the rubber on the tube as the hose clamp will keep it from sliding over the flare. Also use a new crush washer under the fittings on the tranny .
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
Turbo 350 Leaking & Kickdown Problems... onefine56 Transmission - Rearend 2 01-06-2008 09:28 PM
newer sbc 350 to older turbo 350 yragat Transmission - Rearend 8 10-20-2007 08:52 PM
Filling a new turbo 350 bentwings Transmission - Rearend 2 09-29-2007 10:26 PM
Turbo 350 Transmission leak wfd102 Transmission - Rearend 2 09-01-2007 02:47 PM
