turbo 350 governor - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2007, 10:17 AM
runn141's Avatar
SB S10
turbo 350 governor
would recalibrating the governor for higher shift points make much difference without the passing gear?
Old 08-21-2007, 06:33 AM
turbo 350
Would you qualfiy your question? Do you not have passing gear hooked up and you want to play with the governor?
Old 08-21-2007, 08:31 AM
runn141's Avatar
SB S10
i dont have the passing gear hooked up. and i was wanting to make changes to the governor.
Old 08-21-2007, 12:17 PM
jakeshoe's Avatar
Yes,
Recalibrating the governor works fine without the detent cable hooked up.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 01:18 PM
Turbo 350 not shifting right Gearjammers Transmission - Rearend 5 10-24-2007 06:36 AM
350 or 383 for a Turbo application? Siggy_Freud Engine 15 07-23-2006 11:51 PM
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 01:40 AM
Turbo 350 in a 66 ChevyII sledge57 Transmission - Rearend 1 10-06-2003 05:54 AM
