turbo 350 issues - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 11-12-2004, 11:10 PM
D. Robbins's Avatar
turbo 350 issues
Just built my first automatic> No power @ take off, second works, and drive works under no load. very frusterating
Old 11-13-2004, 05:19 PM
thewrongshop@yahoo.com
turbo 350 issues
did you replace the torque converter ?
did you flush the trans oil cooler ?
does your trans have the shift cable going
to the carb linkage ? and if so .. dod you adjust it ?
dave
Old 11-14-2004, 10:16 AM
D. Robbins's Avatar
T/H 350 issues
I did not replace the torque converter. The old tranny filled with antifreeze and smoked the clutches. yes the kick down cable is adjusted and i tried two differnet valve body's and two vacuum modulators. I am think now that the sprag(???) roller bearing are in backwards. Just a guess though. thanks for the info and I'll keep searching
