turbo 350 kickdown leaking!!! What to do? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2003, 04:49 PM
New Member
Angry turbo 350 kickdown leaking!!! What to do?
Folks my newly installed motor and tranny look and run great, thanks for all the help with the install... Now the only leak is coming from where the kick down cable screws into the trans. What can I do to fix this pest??? Thanks again for all the help..
Old 02-06-2003, 03:13 AM
Crosley's Avatar
Wiki Edits: 1659
Cool
what type of cazble do you have? An OEM type or something like a Lokar cable?
The OEM uses 2 types,,,, an O-ring (old style) and a sleeve style of seal.
The sleeve type... install the sleeve INTO the case FIRST. Many ppl install the sleeve onto the cable end first and this will result in damage to the sealing sleeve upon install.
