turbo 350 leak? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2005, 03:54 PM
A/G WILLYS's Avatar
turbo 350 leak?
My son has a stock 70 cutlass 350 350 it was leaking transmission fluid out the dipstick at the bottom so I drained the fluid thinking he over filled it, new gasket, filled it back with oil and it wasnt leaking, he went for a ride came back and the car sat for about an half an hour and it started pouring out oil, I have heard of a drain back transmission problem but not sure that's it and what do you do to repair that? Is it the tranny or the torque converter? One other thing the transmission is so hot you cant put your hand on the pan, any information will be greatly appreciated thanks dave
Old 07-31-2005, 08:44 PM
Jmark's Avatar
Was the dipstick the "O-ring" type? Those leak alot and seem to be hard to stop sometimes. I switched my tube on my TH350 to a newer style that takes a large upside down looking "tophat" style seal and its been bone dry every since. Other things that can be leaking are the shift shaft seal and lines. The shift shaft seal is very close to the pan area and can be overlooked for a pan leak.
As far as the leak down, its common for the torque converter to leak down when off.
As far as the heat goes, yes, automatics run pretty hot and can't be touched if driven for very long.
Any chance the front pump seal is leaking? Happens too and quite often when not running. The pressure keeps it sealed until the pressure goes away, then it will dump some oil out. You will need to remove the dust shield to get an idea on the pump seal.
Sometimes a mirror and flash light will help find the source of the leak, along with some brake clean or carb spray.
Mark
Old 07-31-2005, 09:35 PM
A/G WILLYS's Avatar
it's definitely coming out of the dipstick tube but the wieird thing is it's like 15 minutes after you shut the car off and it pours out and the transmission pan is so hot you cant touch it.
Old 07-31-2005, 10:25 PM
Jmark's Avatar
Sorry I can't be more help, but hopefully Crosley or Airworld will pop in and solve the problem. Both are professional builders and know their stuff.
Mark
Old 07-31-2005, 10:30 PM
A/G WILLYS's Avatar
I appreciate the help,, hopefully someone has the answer.
Old 08-02-2005, 06:53 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
If it is leaking at the dipstick tube at the tranny case , pull the tube out to find the problem........ the older design tubes with an O ring will crack there.
Regarding the tranny heat and touching the tranny pan. Heat some water to 150*F on the stove.... touch the pan . Is it HOT? 150*F on an automatic is a fine temp for it to operate at......many operate at higher temps
Do you see my poor attempt to explain the temp thing to you ??
Old 08-02-2005, 08:52 PM
A/G WILLYS's Avatar
thanks for all your help, I think I found the problem the vent was plugged solid and I quess it cause some pressure and caused it to blow past the O-ring so far so good. as far as the temperture my friend had one of those laser temp things that you point at the object and the tranny was around 195? thanks dave
Help with Turbo 350... Jason_R Transmission - Rearend 1 09-26-2003 07:12 PM
350 Turbo, Help Blazemore Transmission - Rearend 2 09-03-2003 06:24 AM
Turbo 350 1980 Malibu Transmission - Rearend 14 07-27-2003 04:24 PM
turbo 350 tail shaft kid Transmission - Rearend 10 04-26-2003 02:36 PM
Turbo 350 Trouble in 85 gmc jdimassi Transmission - Rearend 7 01-26-2003 01:34 PM
